Parâmetro - Zabbix está rodando - NÃO
  • pccruz
    • Mar 2011
    • 37
    #16
    Resolvi o problema brother...
    Eu já tinha alterado o arquivo zabbix_server.conf tirando o usuário
    zabbix, e deixando em branco... Mas não adiantava, no log me
    mostrava que não estava conectando com o usuário root... Me gerava o
    erro:
    [root@omega sbin]# tail /tmp/zabbix_server.log
    2480:20120531:102204.365 [Z3001] connection to database 'zabbix'
    failed: [1045] Access denied for user 'root'@'localhost' (using
    password: NO)
    2480:20120531:102204.365 Database is down. Reconnecting in 10 seconds.
    2480:20120531:102214.367 [Z3001] connection to database 'zabbix'
    password: NO)
    2480:20120531:102214.367 Database is down. Reconnecting in 10 seconds.
    2480:20120531:102224.370 [Z3001] connection to database 'zabbix'
    password: NO)
    2480:20120531:102224.370 Database is down. Reconnecting in 10 seconds.
    2480:20120531:102234.372 [Z3001] connection to database 'zabbix'
    password: NO)
    2480:20120531:102234.372 Database is down. Reconnecting in 10 seconds.
    2480:20120531:102244.375 [Z3001] connection to database 'zabbix'
    password: NO)
    2480:20120531:102244.375 Database is down. Reconnecting in 10 seconds
    Depois com o comando vim zabbix_server.conf inseri novamente o nome do
    dbname, dbuser e password.
    Matei os processos do Zabbix
    Salvei e por ultimo executei o comando:
    zabbix_server -c /usr/local/etc/zabbix_server.conf
    Consultei novamente com zabbix ps -ef | grep zabbix
    zabbix 3140 1 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3142 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3143 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3144 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3145 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3146 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3147 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3150 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3151 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3152 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3154 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3156 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3158 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3160 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3161 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3163 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3165 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3167 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3169 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3171 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3172 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3174 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3176 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3178 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3180 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3182 3140 0 14:01 ? 00:00:00 zabbix_server -c
    zabbix 3184 3140 0 14:01 ? 00:00:00 zabbix_server -c
    root 3227 3065 0 14:02 pts/0 00:00:00 grep zabbix
    • andersguitar
      • Dec 2010
      • 64
      #17
      Show de bola. Só não entendo por que o seu não estava se baseando automaticamente no .conf da pasta /usr/local/etc. Mas enfim, bom que está resolvido.
      • pccruz
        • Mar 2011
        • 37
        #18
        Só que agora estou com outro problema.
        Quando eu reinicio meu server, o parâmetro fica como não novamente, se eu vejo os processos esta como:
        [root@omega etc]# ps -ef | grep zabbix
        zabbix 2560 1 0 07:30 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
        zabbix 2562 2560 0 07:30 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
        zabbix 2563 2560 0 07:30 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
        zabbix 2564 2560 0 07:30 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
        zabbix 2565 2560 0 07:30 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
        zabbix 2566 2560 0 07:30 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
        zabbix 2570 1 0 07:30 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_server
        root 2768 2713 0 07:34 pts/0 00:00:00 grep zabbix
        Se eu mato os processos acima e executo os comandos:
        zabbix_agent -c /usr/local/etc/zabbix_agentd.conf
        Ele sobe novamente, agora tenho uma dúvida. Como eu faço para não subir mais os processos antigos e subir os novos quando eu reiniciar meu servidor?
        • andersguitar
          • Dec 2010
          • 64
          #19
          Rapaz, daí eu já não sei. Mas eu tentaria o seguinte...
          1 - renomear os confs da pasta /etc/zabbix (por segurança) e criar links para o da pasta /usr/local/etc
          Rapaz, lembrei aqui. Deu um confere nos parametros do arquivo zabbix.conf.php na pasta 'php' que contém as paginas de acesso ao sistema?
          • pccruz
            • Mar 2011
            • 37
            #20
            Of course, what do you suggest?
            • exkg
              • Mar 2007
              • 718
              #21
              Oi ... a informacao dessa aba nos diz se o host definido como ZABBIX Server estah ou nao atendendo na porta 10051.
              Faz alguns testes:
              - netstat -nap |grep 10051
              - telnet <IP DO SERVER CFME O TEU CONF> 10051
              - iptables -L -n (e verifica se tem regras bloqueando)
              Mas pelo que entendih tah tudo funcionando exceto isso ... correto ?
              []s,
              Luciano
              Luciano Alves
              www.zabbix.com
              Brazil | México | Argentina | Colômbia | Chile
              Zabbix Performance Tuning
              • pccruz
                • Mar 2011
                • 37
                #22
                Grande Luciano, blza?
                Então man, eu achei uma forma alternativa de resolver o problema, só que quando eu reinicio meu server, o parâmetro fica como não novamente, se eu vejo os processos esta como:
                Se eu mato os processos acima e executo os comandos abaixo ele volta
                Queria deixar isso automático, caso o meu server venha ser reinicializado não precise ficar startando manualmente, tudo isso aconteceu depois de migrar o meu zabbix 1.8 para 2.0
                • andersguitar
                  • Dec 2010
                  • 64
                  #23
                  Falae pc!"
                  Rapaz, provavelmente voce tem no teu 'rc.local' setado lá os parametros para subir o zabbix_server.
                  Experimenta alterar com o parametro -c "..." pra ver se sobe normalmente.
                  • pccruz
                    • Mar 2011
                    • 37
                    #24
                    Opa blza Guitarrista?
                    No meu arquivo zabbix_server tem no BASEDIR esses caminhos abaixo:
                    # base zabbix dir
                    BASEDIR=/usr/local/zabbix
                    # PID file
                    PIDFILE=/var/tmp/zabbix_server.pid
                    # binary file
                    ZABBIX_SUCKERD=$BASEDIR/sbin/zabbix_server
                    É nesses caminhos que devo fazer a alteração?
                    Luciano, segue abaixo os testes que fiz com os comandos que me passou:
                    [root@omega init.d]# netstat -nap | grep 10051
                    tcp 0 0 172.16.21.130:10051 0.0.0.0:* LISTEN 2913/zabbix_server
                    tcp 0 0 172.16.21.130:10051 172.16.22.53:2200 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.105:1758 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.140:4611 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.109:4835 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.120:4854 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.22.80:3015 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.82:37058 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.132:55582 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.195:15407 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.41:32453 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.40:2754 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.31:59104 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.143:6211 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.22.173:3169 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.22.113:1722 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.22.58:53998 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.115:54872 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.189:17550 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.136:4022 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.122:46974 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.22.49:12596 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.0.11:1039 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.100.146:2192 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.62:1603 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.22.60:3392 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.22.172:2007 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.69:32769 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.22.78:63498 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.249:2490 TIME_WAIT -
                    tcp 0 0 172.16.21.130:10051 172.16.21.212:23686 TIME_WAIT -
                    [root@omega init.d]# telnet 172.16.21.130 10051
                    Trying 172.16.21.130...
                    Connected to (172.16.21.130).
                    Escape character is '^]'.
                    Connection closed by foreign host.
                    [root@omega init.d]# iptables -L -n
                    Chain INPUT (policy ACCEPT)
                    target prot opt source destination
                    Chain FORWARD (policy ACCEPT)
                    Chain OUTPUT (policy ACCEPT)
                    • andersguitar
                      • Dec 2010
                      • 64
                      #25
                      Falae PC! Teria como postar o teu rc.local?
                      • pccruz
                        • Mar 2011
                        • 37
                        #26
                        [root@omega etc]# pwd
                        /etc
                        [root@omega etc]# cat rc.local
                        #!/bin/sh
                        # This script will be executed *after* all the other init scripts.
                        # You can put your own initialization stuff in here if you don't
                        # want to do the full Sys V style init stuff.
                        touch /var/lock/subsys/local
                        [root@omega etc]#
                        • andersguitar
                          • Dec 2010
                          • 64
                          #27
                          Estranho não ter configurado parametro para subir o zabbix...
                          Bem, faz o teste:
                          No teu rc.local, coloca aí:
                          zabbix_server -c "/usr/local/etc/zabbix/zabbix_server.conf"
                          Ve se funciona, com o ps.
                          • pccruz
                            • Mar 2011
                            • 37
                            #28
                            Beleza, mas posso colocar em qualquer lugar este caminho? Devo retirar o touch /var/lock/subsys/local ?
                            • andersguitar
                              • Dec 2010
                              • 64
                              #29
                              Pode colocar após o touch.
                              • pccruz
                                • Mar 2011
                                • 37
                                #30
                                [root@omega etc]# vim rc.local
                                #!/bin/sh
                                Reiniciei, depois fui ver os processos e ainda sobem os antigos:
                                [root@omega ~]# ps -ef | grep zabbix
                                zabbix 2562 1 0 14:46 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
                                zabbix 2564 2562 0 14:46 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
                                zabbix 2565 2562 0 14:46 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
                                zabbix 2566 2562 0 14:46 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
                                zabbix 2567 2562 0 14:46 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
                                zabbix 2568 2562 0 14:46 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
                                zabbix 2572 1 0 14:46 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_server
                                root 2863 2738 0 14:51 pts/1 00:00:00 grep zabbix
